Re: SUPER C C-123 Crankshaft pulley removal
Posted by mkirsch on April 29, 2011 at 05:33:35 from (64.80.110.75):
In Reply to: SUPER C C-123 Crankshaft pulley removal posted by Joe P. on April 28, 2011 at 14:12:42:
You can get it off with a big two-jaw puller, a bearing separator, and an oxy-acetylene torch to heat the shank of the pulley.
You're going to need a new seal on the front cover anyway, so why not use some heat so you aren't stressing the bejeezus out of everything.
Like others have said, DO NOT pull on the pulley itself with the puller.
Once it's off, clean the shaft and the inside of the pulley. It'll reinstall easily.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
