Posted by SouthernFarmall on April 30, 2011 at 20:04:58 from (76.4.24.140):
In Reply to: Super C Quit posted by Wi-Ed on April 30, 2011 at 19:25:31:
Take your drain plug out and make sure you have gas inside the carb. After this, take a ball peen hammer or equivalent and tap the side of the float bowl in the carburetor. If that doesn't do it, then make sure you have spark where and when you need it. This means checking plugs, wires, breaker points, and anything else in that system. If you still can't figure it out, take the carb apart and make sure the float is not stuck and there is no crud in the jet. First blow it out with an air compressor, then soak it in carb cleaner, and finally blow it out again before reinstalling. While you are in the carburetor, go ahead and check the gaskets and clean it up real good. I hope you figure it out, SF
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
