you can solder to cast. I put a brand new over flow tube in the top tank of my F-20. soldered it in. No leaks. works. Steel brake line to cast iron tank.
Clean. Flux. correct amount of heat. No prob. clean is the most important for solder. Gene's solution is a very good one, and will work if you are not comfortable soldering it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
