Posted by Tom Fleming on May 08, 2011 at 03:02:03 from (67.20.243.240):
In Reply to: farmall a posted by m smith on May 07, 2011 at 19:47:36:
fuel delivery sounds like your issue. clean all the components of your fuel system. that would include screen on the sediment bowl, check inside the tank, and make sure the inlet to the sediment bowl isn't plugged or restricted. Sounds like you have crud or varnish somewhere. IF the main jet is plugged or restricted, same answer.
Clean fuel delivery components and rebuild the carb.
Only other thing it MIGHT be is a leaking intake manifold gasket.
Try these things and tell us what you find. And don't be intimidated by a carb rebuild if you have never done one before. The carb for the C-113 (A, B, BN, C) is one of the more simple ones.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
