Posted by M Diesel on May 09, 2011 at 11:35:30 from (12.24.61.12):
In Reply to: Max pto speed on MD posted by sflem849 on May 09, 2011 at 06:53:48:
The main thing on an MD is that ball joint in the throttle linkage where the linkage turns down hill over the side of the engine. It never gets greased and wears badly, eventually forming a tongue and groove kind of thing. It creates artificial stops and won't let the travel go to both min and max anymore, just barely reaching both ends. Otherwise there are no stops except those inside the pump.
Standard on an IH ag pump is 11% regulation. Setting high idle is very easy, done by a screw under the pump oil filler cap. It's the one where the screw head goes to the right and the head bumps against the case. Screw it in a little to up the RPM.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
