Posted by pete 23 on May 10, 2011 at 10:00:10 from (74.44.100.190):
In Reply to: Cracked head on a MD posted by Brad in WI on May 10, 2011 at 03:01:36:
I pressure test engines for coolant leaks all the time and it does work. You have to have piston on exact top dead center compression stroke or disconnect valve linkage so valves are both closed at bottom dead center. You will see the air come up in top of radiator if leaking but you of course won't know if it is a gasket or crack.If you use a leakage tester made for this it will show percentage of leakage past all parts like valves and rings. You can also do as other posters have said, take belt off, fill radiator to very brim and run it for maybe a minute. You may not see bubbles but coolant will rise immediately if you have much of a leak. Now days, the modern way is to use the tester in coolant to check for combustion gases. I believe these old engines always leak just a little so don't know if the tester shows any amounts for reading it.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
