I have an H, a 300U, a 340U, a couple of 8N's and the bigger tractors. I fully agree, the 300 U is a thirsty beast. But it does put out the power when needed.
My theory (and I may be wrong). The 300 U has a carb the size of an M carb (large bore) put on a 164 cu inch engine. The H has a much smaller carb put on a 152 cu inch engine. Both engine designs are similar, neither is high tech. The H gives a lot of pull power, and may rival the 300U, but the comparison is not quite fair with the difference in wheel sizes and parasitic losses from the FT hydraulics of the 300. But due to the similarity in cu inches, the CFM of air/gas going through the carb is similar, but the smaller carb of the H gets the air flowing at higher velocity, so it does a better job of atomizing the gas. The carb on the 300 is made for a M engine of ~269 cu inches, so it has a relatively low velocity of air flow in the 300. Thus the gas is not vaporized well, but gets sucked down in bigger droplets. My 300 has always run smokey compared to the H.
Now the experiment, based on the above.... can you physically mount an H carb on the 300 engine? If so, I think you will have better fuel/air mix and thus lower fuel consumption, but not quite as much gut pulling power.
Compare the 340 U with its 135 cu in engine. Much better fuel economy, but this is a newer generation engine (with a small carb like the 8N Ford has). But I'll admit, it does not have the pull power of the 300 U. I do think it has higher compression, and a more agressive spark advance curve in the dist. For small farming and considering the cost of fuel, I prefer the 340 U, although it is not as stoutly built as the 300/350's.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
