I would recommend against two 12V in parallel, unless you're willing to replace BOTH batteries at the same time, every time. One goes bad, replace BOTH.
In parallel the two batteries need to be the same so they charge and discharge evenly. If you put a weak old battery together with a strong new battery, when the old battery goes bad you don't notice it right away. This causes the new battery to get overcharged due to the old battery not wanting to accept a charge. This also causes the new battery to get drawn down while the tractor sits because it keeps trying to charge the old weak battery.
What happens then is a vicious circle of replacing one battery, then the other, then the first one again, then the other again, and so on... One battery keeps ruining the other in turn.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
