You can easily start a 400 without a dash panel in place. You need a couple short short lengths of wire to use as jumpers:
1 - BLOCK THE WHEELS AND DOUBLE CHECK THE TRANNY IS IN NEUTRAL (safety first!)
2 - Use one wire to jumper between the ungrounded battery terminal and the ignition switch side of the coil. (Alligator clips on both ends of this wire will be helpful!)
3 - Use another other wire to jumper between the solenoid's battery and control terminals to crank the engine.
To check for a gross hydraulic leak you can try cranking the engine without starting it by skipping #2 above.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
