Rather than using shut-off valves, most would use something called a "selector valve". It is a three port valve that has one inlet and two outlets. Double selector valves are also available for using on two-way cylinders. Either selector valve is used to disconnect one application and send power to another.
I'd be more inclined to set up an additional hydraulic system running off the front of the crankshaft through the crank hole in bolster or off the IPTO as a second choice.
Perhaps the easiest solution is to take one of the existing three circuits and fit quick disconnects at the hose ends. Run hoses from the new implement to connect with the new disconnects.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
