Posted by mkirsch on May 21, 2011 at 05:37:47 from (67.253.161.186):
In Reply to: IH #8 Plow posted by IAtractorKid on May 20, 2011 at 19:57:36:
There are two models of #8 3-bottom plow. One can be reduced to 2-bottom (#8), the other can't (#8L)
A #8L plow will have a wider pull bar and a third main beam in between the two that are attached to the pull bar.
On a #8, the third bottom will flare out from the second bottom and kind of "stick out" to the left as you sit on the tractor. It LOOKS like it was added on.
Removing the bottom is as simple as unbolting the tail wheel, the beam and the brace. Bolt the tail wheel to the corresponding holes on the second bottom.
The only part you might need is the 2-bottom lift arm for the tailwheel. On the 3-bottom #8, the tailwheel lift arm is bolted to the axle leg outside the frame. On the 2-bottom, the lift arm is clamped to the axle shaft in between the 1st and 2nd bottom beams.
Other than the heavy lifting, it is easy and obvious.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
