Re: Help with Farmall H after electronic ignition install
Posted by Stevishere on May 22, 2011 at 12:45:23 from (24.56.222.202):
In Reply to: Help with Farmall H after electronic ignition install posted by WaltZ on May 08, 2011 at 17:00:25:
I think you are correct. I loosened the distributor, then started moving it CCW a couple of degrees, try to start, repeat.
After moving it about 10 degrees CCW, it started up. I continued moving it until it ran smooth, probably about 20 degrees CCW.
I read that my timing mark is on the crankshaft fan pulley. KNow I need to know how to go about setting the timing correctly.
Anybody out there have specifics?
Thanks! 8)
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
