The best way to do the adjustment is to use a flat surface and a spacer as thick as the lever height measurement. Use a heavy washer to catch all three levers and a bolt through your surface plate or a small plate and a press to hold the levers at the spacer height. Then adjust the levers until you get the right measurement between the surface plate and the underside of of the clutch cover where the mounting bolts are located.
An alternate method is to use the correct height spacers under the clutch cover at the mounting holes and pull the cover down until they are tight. Then adjust the levers until you get the correct lever height.
The first method is best because that has the adjustments made with spring pressure against the levers to take up any movement between holes and pivot pins. With the second method there is no tension on the levers and any adjustment may be off due to worn parts.
Usually you are better off not trying to make any adjustment on the clutch levers because it is very difficult to get the adjustments set as close as a rebuild PPA is set to.
If you really have to make adjustments without the proper setting tools you can get pretty close by having the flywheel off and setting it on a level surface. Once the flywheel is level install the disk and PPA. Adjust the levers until they are horizontal. Use a heavy washer or small plate that will cover all three levers. Put a level on the plate and do final adjustments until the plate is level.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
