more cub problems!
Posted by farmallboy15 on May 23, 2011 at 16:27:23 from (12.213.80.36):
this is a different cub from last week. ive been using it to plant all weekend. and on my back to the barn it started sputtering and i pushed the clutch in and it came back a little then it started sputtering and completly died and refused to start. came back a few hours later and after playing with the choke and throttle i got it to start up and act just fine. put it in the barn and now it wont start at all. it will sputter a little but not run. i read some past posts and switched the coil with another tractor. there was some sediment in the bowl. i have good flow to the carb. but when i opened the drain a bunch of gas came out. when i turned the fuel line on just a trickle came out the drain. what do you guys think? something clogged up in the carb / float problems? thanks in advance!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
