Get into the mowable grass and start mowing. While going straight, shut off the engine and let it stop. Take the PTO out of gear, then carefully look at the grass being cut. Starting in front of the tractor, and continuing under the deck till you get to the blades. This should indicate what is happening as it cuts. Smashed down grass can respond to a second reverse direction cut. Short blades are a real possibility. Be careful to check all clearances if longer blades are used. Do not compromise with the wrong blades. Use OEM or replacement blades made for it. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
