Many people will try tell you otherwise, but I know from experience that in-line fuel filters work fine with gravity feed systems. I got my 140 with an in-line fuel filter, and have kept it that way. The only downside is that the filters must be changed often. If your tank is really dirty, it may be more trouble than it is worth to install one. You may be better off cleaning the tank again. But, if there truly is only a little bit of crud in there, an in-line filter will work fine. In fact, if I were you, I probably would install one myself!
SF
PS: There is a strainer in the carb that will become clogged with crud eventually, so it will be better to have the junk caught where you can easily access it (the in-line filter) than in the carb.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
