A gravity feed fuel system operates at low pressure. Moderate restriction caused by a fuel filter can reduce the fuel pressure to a dangerous level and cause a lean the air/fuel mixture. The air/fuel mixture needed for combustion may not be enough to keep the combustion chambers cool while operating under load. If an engine is running so lean that the piston and chamber have heated up more than tolerances will allow, the piston may grind against the cylinder wall until it freezes. Excessive heat can burn a valve or melt a hole in the piston.
It would be interesting to find out if melted pistons are a common failure in IH engines?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
