1586 clutch, trans, problems
Posted by MNHighwired on May 29, 2011 at 21:49:52 from (75.221.161.176):
I was using my IH 1586 on a JD 30 ft field cult when it stopped dead in the field. The motor runs fine, all hydrolics work fine. I can put it in any gear and it will not move including reserse. The TA can be on or off still no moving it on its own. Whats should I look for? A friend of mine who helped me pull it home thaught that the clutch pedal pushed a little to easly and thaught the clutch was out. Today I hooked a chain on it with my Ford 545 loader tractor and pulled the 1586 ahead when the tractor was in park. I had the RPM very low, in first gear in the 545 when I pulled wanting not to hurt anything else in the 1586. The 1586 pulled very easly ahead. the tractor motor was not running. The person in the 1586 said he could here a light ticking sound when I pulled it. So instead of a bad clutch maybe I have a bad transmission. Or my clutch is out and I took out my parking gear pulling it? OH Well. Any Ideas. Thank you and have a great day.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
