Re: Farmall h
Posted by Theman on May 31, 2011 at 14:51:24 from (65.198.133.254):
In Reply to: Farmall h posted by volkswagen on May 30, 2011 at 19:28:34:
From what you describe, the broken spring is a counterbalance and that very well could be the problem. To eliminate the possibilities, I'd disconnect the rod of the non-moving cylinder (don't let it fall - block it up) and make sure the cultivator linkage/mechanism isn't in a bind. Then check to see if the cylinder will extend without a load. If it doesn't extend, you may have a plugged or collapsed hose, or the cylinder itself has seized. Being a one-way system, you know the cylinder isn't bypassing or it would be leaking oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
