Posted by TWheat on June 03, 2011 at 16:14:35 from (67.233.24.90):
I don't want to hijack Cuttman's topic, But Jim N said "An oil pressure switch that is open with no pressure, and closed when under pressure is ideal for this, as it is automatic (NAPA has them). The wire with diode goes to this new switch ("T"ed into the oil pressure port.) and the switch is supplied with voltage from the starter switch on the hot terminal. A plain SPST toggle switch can be used in place of the oil pressure switch, but it must be turned on manually and off manually each time the tractor is operated." I haven't been able to get it fixed in my mind how the engine could start if there was no current because the oil pressure switch had the current cut off. Are you saying that the oil pressure switch is wired to energizing the starter , cranking the engine with the starter, temporarily providing that current until the engine starts and builds oil pressure?? Thanks, TWheat
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
