Remove the spring and linkage components from the lever. Use a Oxy-acetylene torch to heat the housing where the shaft comes out. (Heat only n the housing/bushing, not the shaft.) let it cool. Put penetrating oil on it PB Blaster, or Other juice. Take a large adjustable wrench and move the lever Cw, then CCW repeatedly and see if you can get it to budge. Repeat the heat step and cooling until it does. The worst is to loose the tin cover, which is not uncommon, and not terribly expensive. Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
