Yes, you can split it in front of the transmission. It's not as much trouble as splitting at the clutch. Make sure you don't disengage the clutch while you have it split so you will be able to get the shaft back through the splines in the clutch plate. When you split, you can separate it enough so you can get to the coupling in the shaft and take it apart. then you can roll the rear part back. when you do this, the back part is nearly balanced, so it just takes a shop lift of some sort to steady it as you roll it back on it's own wheels. Make sure the front part is well supported so it does not tip over.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
