The most likely cause is a failure of the IPTO hub and shaft/gear in the back of the clutch pressure plate assembly. If you remove the cover under the clutch you can see the parts in front of the release bearing. Make sure the shaft and hub are turning with the PPA.
When the splines wear out they usually make noise for a little while but if run enough they will quiet down as they splines wear more. The rivets that hold the hub to the clutch cover may be what failed. In that case they will make little or no noise.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
