Posted by Pat-CT on June 05, 2011 at 13:19:50 from (68.9.37.25):
In Reply to: Farmall H stalls posted by REK on June 05, 2011 at 12:22:26:
If you do not get fuel flow like what old is describing, check the inlet screen on the carb, possible clogged, Check the fuel bowl for a possible clogged passage, blow it out with compressed air OUTSIDE. Drain the tank, look inside or in the gas that you have drained to see anything that might get sucked over the outlet of the tank. If you see none of these things, You may have a carb problem or a ignition problem.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
