Posted by Seth Boyer on June 05, 2011 at 17:19:31 from (72.161.227.108):
I have two carbs that I'm working with. I just realized that they have different part numbers 29954-DB and 29953-DC. By my book, and correct me if I'm wrong, the 29954 is a kerosene carb and the 29953 is gasoline. The only difference I can see is the venturi. Kerosene carb has a lot smaller venturi than the gas. Kerosene labeled 21 and gasoline is labeled 24. I'm assuming it would be best to use the gasoline venturi. Is this correct? Also what other differences is there between the two carbs that I'm not seeing?
On both carbs there is a small brass tube that is connecting the lower and upper bodies. I can't tell for sure but I think it's the main air bleed. Correct me if I'm wrong. Anyone had experiance with fixing this? Any idea where I could get something to replace it?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
