Posted by Owen Aaland on June 07, 2011 at 13:44:55 from (216.47.35.39):
In Reply to: Farmall 460D Rowcrop posted by John Athey on June 06, 2011 at 07:20:44:
The shaft coming out of the steering valve was designed to have the front yoke of the universal joint slide on it to allow fore and aft movement of the valve. Over the years many of these splines have worn out and the yoke has been fastened either with a pin through both parts or a set screw in the yoke. It will work OK when this is done IF you make sure there is enough movement in the steering linkage all the way back to the steering wheel.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
