Posted by Janicholson on June 09, 2011 at 18:29:37 from (67.72.98.45):
In Reply to: 230 farmall posted by walkman on June 09, 2011 at 16:13:19:
The candidate most likely to be responsible is the head gasket. There is a passage to the valve train that can put oil directly into the water passages. There are few other choices except a crack in the block into an oil gallery from the water jacket. This is not a probable cause. Leaks from the lower end into the water can't happen because the water is pressurized and the oil at that location is not. Best of luck, Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
