The left rear elbow (outlet) is a delay port. The front left elbow is not. If that is not the problem, three items could be: one is if the two cylinders are not the same diameter. If both have three rods holding them together, or both have 4, they are OK. if one has 3 and the other has 4 it will pick up incorrectly. If the return springs under the cylinders are out od adjustment, or broken, that will also cause it. The two front ports (left and right) in the Liftall are connected together so they bot get the same fluid. If this does not fix it, change hases from one to the other side and see if a hose is restricted internally. One last item, if a lowering restrictor fitting is in the hose (a brownish brass coupling about 2" or so long) it will for sure cause this. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
