Clutch is removable through an opening in bottom of clutch housing. The procedure is as follows:
1). Remove four bolts from the clutch joint. (Marked 1 in picture)
2). Remove clutch release sleeve carrier. (Marked 2 in picture)
3). Remove clutch shaft together with thrust bearing.
4). Remove three cap screws holding clutch to flywheel and after placing washers under the head of cap screws replace transpose them to the three holes provided for compressing the clutch spring.
5). Remove the remaining cap screws and lift out clutch.
6). Reassembly is made in the reverse procedure, but be sure to install clutch shaft before releasing pressure on clutch springs and be sure to assemble clutch joint ring with convex side toward clutch.
Good Luck! SadFarmall
This post was edited by SadFarmall at 16:11:30 06/11/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
