Posted by Owen Aaland on June 12, 2011 at 20:27:39 from (216.47.33.99):
In Reply to: Cub IS Charging? posted by equeen on June 11, 2011 at 14:36:55:
You really need to check the voltage with the engine running. A fully charged battery, when put under a large load like cranking the engine, will have a lower voltage right after the load is taken off. Then it will slowly recover some or most of the lost voltage. That may be the effect that you are seeing. In order for the battery to be recharged it needs at least a half a volt above the full charge voltage. Anything less than about 6.8 volts in not going to recharge the battery.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
