Normal practice is to connect the alternator output wire to the battery side ("hot") terminal on the starter solenoid. However you can also connect it directly to the battery positive terminal if that's easier.
Unfortunately the Delco 1-wire alternator will not accommodate an idiot light. Suggest instead mounting a voltmeter with an on/off switch in the dash to monitor alternator operation. Wire the voltmeter directly between the battery + and a good ground.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
