If it runs off the engine it will be mounted to the back of the timing cover at the base of the distributor, I believe. If it is a belly pump it is a big heavy chunk of cast iron inside the clutch housing with three pipes sticking out, two to the left and one to the right, plus a fill cap on the top. This cap is sort of mushroom shaped and on the right hand side, as seen from the seat. I do not know where you fill the live pump system, however it does use its own separate oil, as the engine needs its oil for lubrication. Zach
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
