The light is the supply for exciting voltage. One lead of the light to the ignition, and one to the #1 terminal on the alternator. A diode will work here, as will a 10 ohm resistor. The purpose is to allow excitement of the alt, while preventing the tractor from continuing to run when shut off. The alternator (when turned on by this voltage, then puts out charging voltage to this terminal. (because both sides of the light, diode, or resistor have system voltage the light goes out. If the tractor is shut off with no light diode or resistor, the alternator voltage keeps feeding the ignition.) The switch does this job OK (as on the neighbors tractor) but requires remembering all the time. Th oil pressure unit is an automatic exciting method as well, but sense the diesel is shut off with fuel, the oil pressure shuts off the alt. The coils in the other tractors are probably 12 volt designed with no resistor required. Hoping this helps, Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
