Re: Farmall 130 Distillate Tractor(with pics)
Posted by Janicholson on June 17, 2011 at 12:49:19 from (67.72.98.45):
In Reply to: Re: Farmall 130 Distillate Tractor(with pics) posted by GRAPE-DRANK on June 17, 2011 at 11:26:47:
From early in the 1900s, Refiners were able to produce a heavier fuel from the crude than gasoline for much less money. It was called tractor fuel, or Distillate. The tractors could run on it if started on gasoline, and heated up (with radiator shutters) so the heavy fuel would vaporize and burn.
The Fuel was low in Octane, and smoked substantially. The compression ratio was limited to 2/3 that of gasoline engines. Different heads, valves, intake/exhaust manifolds, Carb differences, Radiator shutters, Fuel tanks and fuel lines were primary differences.
The combustion was not very complete, and would dilute the oil. As the oil level raised, it was drained to the bottom petcock and new oil was added to keep it usable.
As cracking systems improved, it became more expensive than gasoline, and was phased out entirely (mid 60s would be my guess)
Kerosine is similar, but refined so as to remove the smoke and particulates. A distillate tractor could burn Kero with little issue, but they run best on gasoline. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
