Posted by Tom Fleming on June 19, 2011 at 13:38:54 from (67.20.243.240):
So, the tapped hole in the lower rad tank where the drain petcock is supposed to go, was sealed shut with autobody putty. started to leak. Cleaned it out, and found that 1/3 of the lower right cast iron was gone, broken off.
To correct this, I was not happy about replacing the tank. So, bought a brass spigot valve at Coolsprings show on Friday. Cleaned out the putty, ran a NPT tap in to clean out the threads. Mixed up some JB Weld, and gave it a good slather and installed the spigot valve. Let cure overnight. Spigot works great, but there was still seepage around where the repair was.
One bottle of Bar's Leaks, and 1 hour of running with cardboard in front of the rad to get it hot, and no more leaks. Will post pics later tonight. Will run with the bar's leaks for a bit, then flush her out and add the 50/50 water/antifreeze.
I also did a little research on BAr's Leaks, and read exactl what it is, and how it works. I have always used it before, with good success, and was a little afraid of using it in a thermo-syphon system. Not any more. If you have seeps and weeps, or small holes, I am now totally sold on it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
