Posted by LRRifleman on June 19, 2011 at 16:11:01 from (107.33.192.140):
Hello!
I have a 1958 International Model 340 Utility with a gas engine. Yesterday, when the engine sputtered and died, I thought I had a blocked filter, and upon replacing it, I removed the petcock and sediment bowl, and discovered it was fouled with corrosion. Today, I replaced the fuel filter with a correct fuel filter and replaced the petcock/sediment bowl unit. When I turned on the fuel flow (after refilling the tank) the gas barely trickled into the sediment bowl, so apparently, there is a blockage in the fuel tank at the low point.
My question(s):
1) Is there a baffle at the low point of my fueltank or not?
2) If there is a baffle, how do I clear it and rmove the obstruction?
3) It seems, especially if there is not a baffle, that whatever is blocking the fuel line does not float ... how would I get t out of the tank??
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
