I agree with the other posts. I had milky fluid and was told to over fill by 5 gallons, which does not hurt anything to maintain This level, so I could eliminate any internal suction leaks that could be introducing air into the fluid. If after adding the additional fluid, you still have milky fluid, your gonna have to crack the Tractor and replace an oring like seal between the transmission /differential and the T/A section. This is where the suction tube connects between the 2 sections and drops down into the differential resivour. By the way, over filling will not remove the oring seal issue. Hope this helps, good luck. Tod.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
