I would first use or borrow a laser tach to see what rpms you are actually turning at full throttle now, then go from there.
There is a ball joint swivel that screws onto a rod at the junction of the hand throttle lever right behind the air cleaner inside the mounting bracket on the left side. Replace it if the ball has a lot of play, the only way to tell is have someone on the seat move the throttle lever back & forth while you watch the rods to see exactly where the play is.
Linkages are usually worn at all the pivot points and may need to be bushed to take out the slop at each point.
As mentioned above the governor linkage to the butterfly on the carb inside the housing is always gummed up & sticky, I would try getting that cleaned out & lubed up first, the go to the linkage pivots to see if there is any major wear or egg shaped holes. The governor throttle stop screws may need adjustment also, but I would do that last after all the linkages are working properly.
This post was edited by rhtx55 at 17:03:21 06/23/11 3 times.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
