Posted by Owen Aaland on July 04, 2011 at 17:38:35 from (216.47.33.237):
In Reply to: Twitter posted by mkirsch on July 04, 2011 at 07:06:15:
If the bushing is bad enough to allow the armature to touch the pole shoes it will stop charging. The metal to metal contact upsets the magnetic lines of force causing it to stop charging. As long as the armature is not damaged from the contact you will most likely be alright if you replace the bushing. Check to make sure there is no continuity between the commutator and the armature shaft/plates. Shorts in the armature windings can be tested with a growler.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
