That tractor has a seperate pump mounted piggy back on main pump, and relief valve for the hitch and if the hitch is not being used the flow from hitch pump joins the flow from main pump behind the aux valve mounting. There fore , when you pull aux valve and it makes tractor labor that only tells you the main pump is working and the unloading valve to hitch if most likely ok also. So, that brings you to a weak hitch pump, leaking hitch relief valve which is under the cover under seat or blown internal o-rings in draft control valves or cyl. Could possibly by action control valve sticking but I would have to feel your lever to tell you that. If your hitch will go up and down with no load and follow the positiion control lever all right ( MEANING IT WILL NOT JUST GOT ALL THE WAY TO TOP OR BOTTOM) I would think your linkages are ok.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
