Posted by K-Mo on July 06, 2011 at 07:46:21 from (67.55.164.37):
In Reply to: 184 lo boy PTO posted by KDMielke on July 06, 2011 at 05:31:48:
The 184 was built 1977-80. If you own a 184, you need a service manual (GSS-1408). You can get a good quality reprint from www.binderbooks.com
There isn't any relay. Just the Ignition Switch, PTO Switch and Fuse. When the clutch is not working, check for 12V at the clutch. Also check for a good ground connection. If not 12V check PTO Switch and wiring. If you have 12V, 1. Check the brake plate clearance. 2. Check for clutch coil resistance of 2.6 Ohms or for 4.61 amps current draw. If coil resistance or current draw is incorrect, the problem is in the clutch coil. K-Mo
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
