oil leaks
Posted by freefour on July 07, 2011 at 06:33:45 from (216.124.211.18):
Got a couple simple questions about my newly purchased B. I have noticed a small fresh puddle of oil under the shifter each night after I used it. So I cleaned up all the area under and found it is leaking between the transmission connects to the front half of the tractor (see pic). Not sure what it is called.
I believe it has been leaking for a while. I want to check the oil level and make sure there is enough in there. I found the plug on the side where you check the oil level and see where you add it on top by the shifter. What type of oil should I use? I figured it uses like a 80W-90 gear oil.
Also, is there anyway to fix this or even slow it without splitting the tractor? I don't know if that is something I can tackle or have the tools to do so. Thanks!
third party image
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
