Posted by Janicholson on July 08, 2011 at 11:16:41 from (199.17.6.66):
In Reply to: New to me posted by VAJerry on July 07, 2011 at 16:40:41:
As stated,the coil is original. With the tractor running, measure the voltage at the coil terminal going to the ignition switch (not the distributor) if it reads 12+ volts, that coil needs a dropping resistor (mid 60s Chevy, or Chrysler ballast resistor will do it). The coil should be attached to match the battery ground. (it is probably backwards now) The Negative coil terminal should go to the distributor (where it finds ground through the points) Positive to Switch. Very nice Tractor. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
