Posted by D Slater on July 08, 2011 at 17:27:44 from (184.15.35.247):
In Reply to: Belt Pulley Lever SM posted by TV Iron on July 08, 2011 at 15:09:29:
Intended IH way was on the brake pedal side up to and including tractor serial # L 504801. Higher serial numbers went on the clutch pedal side. Different boxes were installed or added over the years, so you may find different than above. Above serial 504801 also used a starter and choke pull rod in the same bracket above the clutch pedal on non diesel tractors whether or not is has a hydraulic tank under the gas tank. Should have battery box under seat also.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
