If you have the piston out, blow it out real good as there is a small orfice in it, check to see that it still has spring tension on pin of piston, put on a new o-ring and try it. Try to look in at the ball and seat to see if any foreign material is under the ball. The o-ring is a special S treated o-ring, they always had the part number stamped right on the o-ring, don't know if they still do. If you have to take out the whole draft control valve and cyl it isn't all that bad, just some pesky linkages to contend with.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
