SA used the nut and the shaft is tapered. Earlier oned used the square out-put shaft. Check your steering shaft for end play cause if the bearing on the end of the worm has play it will give steering wheel plenty of free travel. You can tell if its worn when you turn the wheel see if the steering shaft has end play. There is also a bearing in the sector and some bushings also look for play if the woodruff key is loose on the gear. The worm and gear usually arent bad.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
