Ok, gave it a go. Tried the first suggestions and polarized the generator. Then went and polarized the regulator. Hooked wiring back up, no discharge! Fine, pulled ignition switch on, slight draw. Turned on lights, bigger draw, still not as much as before. Turned them all off, everything fine, no discharge. Started tractor, fired up fine, after a few seconds, starts showing a charge, good huh? Even tested output with meter, about 6.85 at the generator but only 6.72 at battery terminal on regulator? Normal? Let it run a few minutes still charging and no heat(did run with cover off regulator so I could observe while running)seems fine. Shut off tractor and it goes right back to high discharge on ammeter! Disconnected generator terminal to stop it from discharging and was a good spark! Still drawing at generator? Dang it!What to try?
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
