Re: 1066 fuel pump timing
Posted by Owen Aaland on July 09, 2011 at 19:09:18 from (216.47.33.237):
In Reply to: 1066 fuel pump timing posted by tom schwegel on July 09, 2011 at 19:02:35:
Line up the pointer in the flywheel opening with 18° BTDC. With the pump drive shaft in the retarded position, install the pump with the marks aligned. If the engine does not start readily after the fuel system is bled rotate the pump shaft one turn and try again.
If you work at it hard enough they will run with the pump 360° off but they will have no power and really smoke.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
