Posted by pete 23 on July 10, 2011 at 08:25:24 from (74.32.234.149):
In Reply to: Re: Pete 23 Again posted by Allan In NE on July 10, 2011 at 03:04:28:
Allen, see number 16 in the illustrtion. That is the tappet that runs off the camshaft and lifts plunger in pump. There is a groove in the side of that tappet and a pin is pressed into the housing and that tappet is guided on that pin. Now the roller part of tappet will seek it's own center over the cam shaft lobe so it might work for ages with out that guide pin but I sure would not be the one to tell you to run it that way. The pin apparently worked it's way out. Normally they just get loose and start leaking . Will it cost more to repair it later or do it now, I don't know so it's your call. It might run longer than you and I. You can just clean it up good and find a "short" plug and tap it in with some locktitie or a lead type carb plug like you suggested.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
