Re: squealing noise when ta is engaged
Posted by mkirsch on July 12, 2011 at 05:16:17 from (64.80.110.75):
In Reply to: squealing noise when ta is engaged posted by thomas gipson on July 11, 2011 at 13:24:03:
You just had this work done and it makes the noise?
Who cares what it is at this point? The dealer/mechanic should make good and fix the problem(s). What do they say?
As for the remote, did you replace the correct remote valve? Under the seat, left is right and right is left.
Did you get mixed up and reinstall the old, bad valve?
Is the problem always with the same implement? Have you tried different implements? Have you tried the same implement on the other valve?
If you replaced the correct valve and the same thing happens, either both valves are bad, or the hydraulic cylinder is bad.
Valves and cylinders can be rebuilt. It's usually just a matter of replacing worn orings and seals.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
